I have a B7800. I have noticed that one of my rear lift arms seeps slowly while the other does not. Does anyone know what would be involved to fix this? Thanks
Are you taking about a small fluid leak?I have a B7800. I have noticed that one of my rear lift arms seeps slowly while the other does not. Does anyone know what would be involved to fix this? Thanks
As the two arms are connected internally via the rock shaft.
The arms are attached to the rockshaft with splines and are held in place by a snap-ring on the end, remove the ring, remove the arm, and replace the O-ring and reassemble, very easy fix.
Worn splines or broken arm or rock shaft is about the only way that is going to happen.Wolf,
that is what I was thinking (didnt have the names in my head) how can one side move and not the other ....unless the splines are bad?
Thanks for all of your replies. It sounds like I have a little more investgating to do.Worn splines or broken arm or rock shaft is about the only way that is going to happen.
Unless the adjustable arm is backing off???
