jyoutz
I’m thinking about installing Led lights on the canopy of my MX6000. A eight inch flood/spot bar facing forward, and a 4 inch work light facing the rear. I have easy attachment locations under the roof of my canopy to do this. My question relates to wiring. I can buy a wiring harness for the lights that includes a switch, fuse, and direct battery connectors. But I’m wondering about the stubbed out factory wires under the fender that are designed for work lights. If I splice into these wires, can I avoid the battery connections, fuse and switch? On my old JD, I used the factory connectors and it was great. They lights activated when I switched on the factory headlights and shut off with the ignition switch. Will the Kubota factory connectors do the same? Is there a Kubota wiring connector built for this, or go I just use generic connectors and electrical tape? Thanks for any information you can provide.
