Led light mounts
08quadram
bx2350d; Taylor Way 48" tiller; Farm King 50" snow blower
Apr 28, 2014
289
strawberry point, ia
Only issue i have with this set up is when blowing snow at night i get blinded until I'm turned around with my head between them. Otherwise seems to work great.
wozza
BX2370
Mar 12, 2017
45
Perth, Western Australia
I tried to.....
When I click the search function, the window only stays open for like 2 seconds, then closes. Not enough time to type a question
Did the same for me... I did manage to search though.
http://www.orangetractortalks.com/forums/search.php?searchid=3003261
I did a lot of research before setting mine up. Used the existing work light circuit and put in a relay & switches so that the lights only work of the ignition. I'll see if I can find the original thread I worked my ideas from.
coachgeo
Nov 16, 2012
2,459
37
Southern OH
I tried to.....
hmm..... Do you have a pop up blocker or Ad blocker? If so try opening search again then check your blocker to see if it list the URL for the search.... if so select to allow it.
You can also use an advanced search feature that allows you to search a specific website. Odds are your preferred search engine (Google, Bing.. etc.) has that feature. I do it in google all the time. Also often sort results to specific to search with in the last year to get the most up to date info.
