Hi guys
I have a KX71 with a Kubota V1505 4cyl diesel engine on it.
Had a call today from the guy that runs it saying it is pushing diesel into the sump oil when running.
The seals on the 4 'plungers' that bolt in the top of the injection pump have been replaced as it was leaking diesel from the top of the injection pump. That problem is solved.
Any ideas what could be causing this? Its a new one on me!
I'm not with the machine and have very limited time with it in daylight, so hopefully I can gain some ideas of things to look at to best make use of time when I am there or get the guy who uses it to check it out.
Thanks
Jim
Thanks
Jim
