Lawn tractor mower belts: Kevlar vs standard ?
Drifthopper
2000 L3710 HST w/ Woods 1012 FEL. LandPride FDR2572, 60" Brush Hog: Need 60" BB
Apr 22, 2022
86
65
Western New York
To prepare for the up coming lawn mowing season here in WNY, I need a new belt for the Cub Cadet.
The belt from the engine to the deck.
Searching belts on E bay and Amazon......
Is there any great difference between the regular black belts vs the kevlar grey / green belts...?
I can get a regular belt for $19, and the kevlar for $29.
In the big picture of things.... only a $10 difference, but was just wondering if any one had any input whether the kevlar lasted longer then the standard belts.
Thanks in Advance.
8,207
Kevlar handles shock loads better than Standard belts.
If you have a nice clean yard that you just run and run the deck without shutting it off, then Standard.
If it's got places that you hit rocks, mounds, duff, or lots of starts and stops, then Kevlar.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,421
1,706
Kalamazoo, MI
Kevlar seems to hold up better around the idlers found on most mower decks.
6,302
Std. belts are designed to run from pulley to pulley and not have anything pushing on the back side.
Most deck belts are not easy to install, so I'd install the kevlar just to reduce working on the thing!!
4,552
Kevlar tends to be more durable for back bend setups, which includes most mowing decks.
Drifthopper
Apr 22, 2022
86
65
Western New York
Just my experience. My old cub cadet has two drive belts on the same pulleys running from the engine to the pto shaft. These belts also are controlled by the electric/vacuum switch mechanism to turn the deck off and on, and do some slipping as well as take the abrupt shock when the deck is activated. I once used cheaper, although Kevlar belts in this location only to find out they could not take the load and did not last a season of grass cutting, whereas the original proper belts lasted many years. I ended up going back to OEM spec belts for this location. The deck on mine is pto shaft driven, with a belt snaking around the pulleys on the deck. I can get a full season, at least, with the cheaper Kevlar belt in this location on the deck pulleys.
The engine to deck belt is the old i need a back for.
mine has a horiz shaft, so the belt comes down and does the 90* angle to the deck.
The one that wore out last season was a few seasons old, not sure if it was a regular or Kevlar...?
I put an old one on to finish the mowing season, I'll run it till it goes, but i don't want to be in the middle of cutting the grass , have the belt go, then not being able to finish.
5,531
FWIW when you're done for the season, release the tension on the mower drive belt,if you leave the deck on. If it just sits in one place for 3-5-7 months, it'll make a 'divot' or 'kink' in the belt where it goes around the smaller pulleys.
Some machines really question the thought processes of some 'engineers', requiring you to take half the machine apart in 1-2 hours THEN there's the AC130 I have, 30 seconds and no bandaids needed.
I think I have grass ,somewhere under the 2' of white here...and another 3" tonight...Spring in 2 days ??
Flintknapper
L2350DT
May 3, 2022
1,870
2,357
Deep East Texas
Consider also what 'type' of belt was intended for your Lawn Tractor (in that location). There are 'wrapped belts' and 'Raw Edge' belts. They have different design parameters and performance characteristics.
For instance 'wrapped belts' typically are designed to 'slip' a bit under certain conditions.
Donystoy
Dec 10, 2013
651
289
Binbrook, Ontario
Just stay with Kevlar belts. I went through this a few years ago trying to save a dollar. Having retired from the HVAC industry I went to my wholesaler and purchased regular Gates belts for the hydro drive on my JD345 lawn tractor. Was lucky to get a year out of them before chunks started breaking off. Kevlar belts are designed to handle considerably more power than regular belts. The Kevlar belt that was on my B7200 mmm was still the original from 1985.
5,531
to all the other Canucks...
Princess Auto
has several sizes of their belts on sale, less than 1/2 price !!! I just ordered triples of the ones
I use,though I bet I forgot the ONE size that I'll need 3 days after the end of sale.....
Bugzilla46310
2022 BX2680 198? AC 916H
May 22, 2022
183
184
Demotte, IN
Check out V Belt Guys. Been buying belts from them for a while. Been very happy with the quality and pricing. Very quick shipping also.
motionclone
May 4, 2018
1,399
996
Maine
kevlar seems like the bulletproof solution
5,393
2,083
I'm only gonna say this.
Be careful with buying ebay stuff as I'm finding a lot of gimmicks.
research belts.
That was part of training I went through with kubota, about belts. There are different types for different applications and one type may not be the best for certain applications. The gray colored sheath on some belts? Those are mostly reserved for applications where slippage is going to happen, it smooths the engagment and allows a small amount of slippage. Blade belts and traction clutch belt-tension engagement are a good place for those. Fan and continuous tension transmission belts don't need it. Just an example.
