LA 350St Loader. Removal
Marcusaglass
Kubota st30
Dec 30, 2023
Boston
First time tractor owner looking for any advice on removing the front loader. I have found the front and rear pins I believe I need to remove, but have no figured out how it is supported at the back of the loader upon removal. There are 2 bars which are clipped inside of the front arm and a further 2 which are running across the tractor just in front of the steering wheel, if any of you could point me in the right direction I would be extremely gratefu!.
7,157
I had a BF300 on a B8200 and I think they are similar.
The two arms located near the steering wheel go into clips on the outside of the bucket. There were two "L" shaped bolts at the front of the tractor the are removed. There are wedges at each loader tower (the big vertical metal on each side) that have a nut holding a wedge on each side. Remove the wedges. There are two 3/4" square stand pieces that have a bend on one end. That bend fits into the loader tower to support that end.
Maybe that is enough to get you started. Maybe look on YouTube for first person guidance.
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
Is it similar to this tractor/loader?
Marcusaglass
Kubota st30
Dec 30, 2023
Boston
Many thanks, just what I needed
Marcusaglass
Kubota st30
Dec 30, 2023
Boston
Many thanks will be a massive help
