I am the new owner of a L4350 tractor w/loader. I purchased it with a bad/disassembled engine (V2203). I purchased it because I already had a replacement engine sitting around. My replacement engine saw original service as refer compressor power supply, made by Carrier. The obvious differences are an oversized oil pan and a different gear case cover. I'm assuming the intake and the exhaust manifolds will need to swapped out as well. I am in the process of ordering the necessary gaskets and o-rings. I'm in the New Orleans area.
Has anyone else done a similar swap?
My research, so far, tells me that the L4350 had a V2203 DI engine, my eng serial no: DIAW1442. I don't know if my replacement engine is direct injection. My engine serial no is: V2203 122379. I plan on using this engine.
I may chose not to change the gear case cover, I may try to use the carrier configured gear case cover, will check it out.
Thanks
Dave
BX2200D, JD430, JD400, JD430, JD400 backhoe, Ford 340 backhoe, JD450 dozer
Thanks
Dave
