The 4240 has 4 ports in the rear (2 circuits) and the 4310 only 2 ports making one system that is controlled by the stick/lever on the valve at the operators seat.
We want to put a 3 point log splitter on either unit but need a set of ports on the back that are not controlled by a valve bank already because the valve bank will be on the splitter. Is there an easy way to tap into the existing valve bank on the tractor now to achieve this or does something need to be added or replaced ?
