L4150 dt NO PTO,FWD, REV, no work gettn done either.
outdoorfan
L 4150 DT
I have never owned a Kubota until.....I recently acquired a 4150 DT,
I used it every other day for a month or so, and had no issues. I parked it one night, the next morning though, I have no PTO, and no FWD or REV. however the bucket still works, and she starts just fine. what in tarnation just happened here fellas?
I was an auto mechanic for years, how ever this beast is no darn car.
help me out here people.
Tooljunkie
May 13, 2014
4,150
27
No noise?
There may be an inspection cover on the so-called bellhousing, may be worth starting there. Im assuming its a gear transmission,not hst so in all likelyhood its a clutch issue. But the pto part confuses me,as its a live pto.
5,132
The fact that you have no power to the PTO and to the wheels most logically point to a blown clutch (can have a single disk or dual disk clutch) or main shaft coupling.
It does sound really odd that it was working fine then nothing, usually either issue will make noise or would have been slipping.
rbargeron
Jul 6, 2015
1,150
220
western ma
I did check and I tried both Hi and Low. when I engaged the PTO it is hard to turn by hand but I can spin it. When the PTO is in neutral, it spins freely.
Sounds like linkage is disconnected or in neutral somewhere?
Your PTO sounds normal - it has 2-speeds and a H-N-L selector. The main transmission also has Hi-Neutral-Low range selection for 8 travel speeds. The main clutch is either dual-disk with mechanical shuttle, or single disk with hydraulic shuttle. Which setup does this rig have? Any lettering on the hood?
