L3830 fel
ajryan
pembroke,maine
i changed over to the quick attach bucket system. I have less lift capacity and breakoutforce now than i had before, which i might add i was very disapointed with. The loader is a L723. has any body else got any complaints. The l3830 should be able to lift and curl something ......
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
78
Rocky Face, Georgia
I put a QA on my loader and could tell a small difference but it sure wasn't enough that I would change back to the old way. I use my loader alot and it does fine as far a digging power goes.
Was it a Kubota QA or a aftermarket?
bcbull378
GL3830,fel,brush hog,pallet forks,disc,gannon,auger,springtooth,plow,drag,ripper
Sep 6, 2011
579
32
Ventura Ca
I have a Grand L3830 with a 738 fel no complants here does a great job.
dmanlyr
L3200, Hustler Super Z
May 30, 2012
330
Graham, WA
Perhaps your maximum hydraulic pressure is a bit on the low side. Have you checked it against specs?
David
Bulldog
Mar 30, 2010
5,434
78
Rocky Face, Georgia
LCWELL, if you do lots of dirt moving you should consider adding some teeth to your bucket. It's a night and day difference when you are digging in the dirt. I couldn't do without mine.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
Future reference.. If you're trying to move another slab of concrete like that try and get it in the center of the bucket if you can. That way you'll get equal lifting power from both lift cylinders. It kinda looked like that was why your tractor lifted up and twisted on the rear end. Or I missed something and the left front tire dipped down in a pocket in the dirt.
