L3800 Starter won't disengage
TEM087637
L3800
Aug 24, 2015
Whitakers
Got a L3800 thats been giving me some problems starting lately.....sometime acted like battery was dead then click click multiple times.....this was not every time...problem is not battery...yesterday same thing but when it finally started now the started wonted disengage..removed starter cleaned made sure everything moving as should and as soon as i hook battery back up it starts turning over with key off.....HELP PLEASE
9,149
It's a bad starter, replace it!
Sounds like when you took it apart your either missed a broken or damaged part or you have something not put together right and is causing the solenoid to stay engaged! ;)
CaveCreekRay
Jul 11, 2014
2,631
105
Cave Creek, AZ
Hst?
Year?
Hours?
General condition?
Orig owner?
Any mods?
Info PLEASE.
TEM087637
L3800
Aug 24, 2015
Whitakers
dont think its the starter...i have 12v on the black wire with the plug on the end going to solenoid with the key off....thinking it maybe a starter relay...if so where is it or maybe the key switch
9,149
Yes the more information the better.
I'll look in the manual when I get back home in a few hours. ;)
8,576
Is the main power wire contacting the connector on the small wire? Seen that one done a few times when someone gets in a hurry hooking the wires back up and not paying attention to the relation of the connectors. Done that one once or twice myself :eek:
