Hello All,
First post,,, glad i found the site.
I have a L3450 and i broke off the drain plug that is on the brake case housing. (three point pin came out and the lower arm jambed into the cast iron case)
I am stuck at the axle case. I removed all of the bolts and everything in the way. Looking at the Kubota parts diagram, I see nothing holding it?????
I do not want to force it. If i can not weld the brake case the new one is 600+ so i do not want to cause anymore damage.
In the third picture, it feels like a clip may be holding it in the area of the screwdriver tip.
All help is appreciated.
thanks in advance
Chris
thanks in advance
Chris
