L3400 starts and dies within a second
Kleus
10
Tomball, Texas, USA
I have a Kubota L3400 HST that suddenly died on me. When I try to start it, it turns over and runs for maybe a second at most and dies again. I can repeat this over an over. It will only run for this second when turning the key from position 1. If I try from position 2, nothing happens.
SidecarFlip
Banned
557
Bad lift pump or a faulty fuel cutoff solenoid. You need to check the pressure at the hand pump on top of the spin on fuel filter to make sure it's firm and pressurized before anything else.
Roadworthy
L2501 HST
Aug 17, 2019
1,647
528
Benton City, WA
From following posts on this site I've learned (some?) fuel cutoff solenoids have a start position and a run position. Start pulls the solenoid into place and the weaker run coil holds it open. Your run winding may be open. Get a schematic and check out the solenoid.
SidecarFlip
Banned
557
Most Kubota's at least the mechanical injected ones have a plunger type pressure pump on top of the fuel filter housing that initially pressurizes the fuel system so the pump will draw fuel. If the pump knob is soft, there will be no initial pressurization of fuel and the motor will start but shut right off.
I'd start with that. It's the easiest thing to diagnose.
5,257
1,042
The Scottish version of the WSM shows both pull and hold coils of the stop solenoid wired together.
What is also apparent is the OPC timer's involvement with the solenoid.
If the tractor's wiring looks like this one, start by checking the 5 amp OPC timer fuse.
The Scottish wiring may not be the same as the North American tractor's.
lugbolt
ZG127S-54
Oct 15, 2015
5,450
2,140
Mid, South, USA
it ain't got a hand pump filter housing assembly on a L3400HST. It's got a cheap plastic housing with a filter inside of it no pump on it
it has a lift pump on the side of the block, no manual lever on it (unfortunately). Seldom failure point. Usually when the other techs suspected a failed lift pump, I'd ask them to check for fuel in the crankcase. If none, do a fuel flow test from tank to lift pump. Should flow on it's own (tank is mounted higher than the filter housing). If no flow, has a restriction in the line somewhere-or plugged filter or filter housing restriction. Just work your way back.
need fuel air compression to run. Which one does it lose within a second or two after starting initially? I am suspecting a shutoff solenoid or wiring or control issue but the issue was not described very well, so that's all we have to go on.
19thSF
B2650, loader, MMM, pallet forks, tooth bar, rear blade, JD 318 w/plow, JD X350
Mar 1, 2020
408
123
Glendale, Rhode Island
This may be a long shot, but my tractor was doing something similar. It turned out to be a clogged fuel cap breather port that was preventing air from getting into the tank, which created a vacuum, preventing fuel flowing from the tank.
As I say, a long shot.
Good luck with your problem. I hope that is is resolved by 2021! :)
NHSleddog
B2650
Dec 19, 2019
2,144
1,837
Southern, NH
On my B2650, if the treadle pedal isn't sitting just right in the center, I will get this exact scenario. Starts instantly for a second and then shuts down.
SidecarFlip
Banned
557
Dude in the picture has a ,lot of keys on his ring...lol
