L295DT Tie Rod
Tgore76
Kubota L295DT, L1200 FEL
Aug 6, 2021
North Carolina
My tie rod ends are shot, and it looks like rod is bent anyways. I also wouldn’t know how to adjust new ends only. Is there an aftermarket assembly for my tractor with rod and ends I can just replace? I’m not finding part numbers from old manual or Google search.
Tgore76
Aug 6, 2021
North Carolina
Re-posting my old question. Can anyone help with part numbers and/or source for L295 DT Tie Rod and both ends?
11,015
In order to give you an answer would need the tractors serial number, as there is several options.
WAS BANNED FOR NSFW PICS
5,164
I will try to look for it this afternoon. Any idea of where to find it on this old gray market, painted over tractor?
A good flashlight and some patience is what it is going to take. If it has been painted over, and you get lucky, you might be able to remove the paint on the old sticker and find it. If not, you are Sh*t Out of Luck, up the river without a paddle, or blowing in the wind. Take your choice. The sweetness of buying a grey market tractor is soured by the lack of support you will get from the domestic dealers in the US.
A friend of mine learned that when he purchased a grey-market Mercedes. The only place he could get parts for it was in Germany, and it took months to get them imported to the US. He had to find someone in Germany who was willing to buy them for him and then ship them. More than once people would take his money and then he wouldn't ever hear from them again.
3,076
If it is a L295 the serial number is in two places
on a nameplate on the left side by the clutch pedal
and stamped into the transmission case on the right side of the transmission
11,015
An L295DT is no where close to being a grey market Kubota.
Tgore76
Aug 6, 2021
North Carolina
I’m sure I made a wrong assumption off previous research…or my understanding of what “Grey market” means, or perhaps just the difficulty I’ve had finding parts!!?
it is a L295DT and I believe the loader is a 1200!? I have procured manuals/parts lists for both.
everything is painted over. I will look for the serial number next time I’m back out on my property.
Had the commercial/off-road tire store show up with new rear AG tires today… only to find out that at some point somebody put turf tires on it and change the rims - AAARRGH….. so now I’m looking for rear OEM sized rims and a tie rod assembly and I need to find a fuel tank that doesn’t leak…. But we’re making progress.!
3,076
Contact @007kubotaguy for used parts for your tractor. He is in California so shipping may be a costly deal. He has a salvage yard for Kubota L series.
There is a private messaging system that shows up as an ENVELOPE in the upper right hand corner
Tgore76
Aug 6, 2021
North Carolina
Sorry for the much-belated reply! I’m just getting back to working on this tractor.
My Serial # is 13306 - so the “earlier” model.
My research and answers from AI contradict and have my head spinning - multiple part numbers and contradictory information on 2wd vs 4WD compatibility.
Any help with determining the correct tie-rod component part numbers and/or availability would be appreciated!
3,076
Here is the right hand (passenger side) tie rod end
The other side is obsolete but part number is
Kubota #34350-12700 ASSY END, TIE ROD
