L2850 leak!
eyeballer
L2850GST, loader, front snowblower
Apr 1, 2017
copakefalls new York
I've got an 89 l2850,had issues with the hydraulic pump. .that's fixed..now the line coming out from hydro/steering side goes down into the filter assembly is leaking pretty bad..does anyone know if there's an O ring behind the cover where it goes in? Covee has 6 bolts around the perimeter..thanks Charlie.
Sent from my SM-S820L using Tapatalk
11,035
I don't know what cover your talking about?
Can you give a picture of what your having an issue with?
eyeballer
Apr 1, 2017
I'm trying to get a pic posted. .having issues. .when you look down on top of pump,there's the fel out port to the right(banjo)..to the left side is the out port for the tranny/steering,where that line goes down behind pump an goes into the filter assembly. That's where it's leaking. It seemed really loose when I took out the old pump.the Kubota dealer said it's supposed to be..I just don't think this loose.I tried tightening the 6 perimeter bolts but they were tight..so I'm thinking there has to be an O ring in there? Does this help?
eyeballer
Apr 1, 2017
We got it fixed..there are 2 o rings behind the cover of the line that runs from top of hydraulic pump to the filter assembly. .kubota dealership said no..had to buy whole assembly at $572! Glad didn't listen to them and took it all apart.
