L2550 won’t start
MBA Farm Boss
L2550
Jan 29, 2015
35
Phoenixville, PA
My L2550 won’t start. Battery is fine. I’m pretty positive it’s either the starter, starter solenoid, or cable. It won’t jump off and when I turn the key, it doesn’t make that clicking sound. What can I do to narrow it down and can I bypass it to get it started temporarily? We just got some large square bales delivered that I have to move tomorrow before I go out of town.
6,639
One of the first, easiest things to check is battery cables. Especially check the ground where it attaches to the tractor frame. Clean it to a shine.
Bad ground equals no power getting to starter.
CapnDean
L6060,ZD1211
Feb 22, 2018
183
Gulfport, MS USA
Description - L2550 starter wont engage. Have you checked the simple things?
Switch in seat? Is pto lever engaged or just slightly bumped? Your issue sounds like a micro switch safety switch thing. Make sure your butt switch is not hung up, pto engaged (I accidentally bump that rascal with my foot all the time) Make sure gear shift is in neutral etc...
MBA Farm Boss
L2550
Jan 29, 2015
35
Phoenixville, PA
I will but I doubt that’s it. I’m thinking it’s something in the starter or switch. I could always jump it off but now can’t. And like I said, it’s not making that clicking sound when I turn the key.
DThrash
7030SU MX 4700
Sep 29, 2015
184
Eutaw AL
I will but I doubt that***8217;s it. I***8217;m thinking it***8217;s something in the starter or switch. I could always jump it off but now can***8217;t. And like I said, it***8217;s not making that clicking sound when I turn the key.
Not a good practice, but take those jumper cables and put 12 volts to the starter and see what happens. Make sure it is in neutral and ignition switch is on.
8,772
To jump the starter on a L2550 is very easy, pull the small connector wire off the solenoid, and jump that small terminal to the large battery connection and it will crank and start.
Make sure it's in neutral unless you enjoy being run over. ;)
