l245dt left rear wheel locks up randomly
spocialblend218
Hesperia, Ca
I have l245dt and every once in a while the left rear wheel locks up. If I roll the tractor back a bit then go forward it will work fine. It only occurs after a complete stop about 1 in 5 times. Any clues on what I should be looking for to repair this?
Also, I can't find it in the owners manual. But how do I check the rear diff oil?
Thanks for the help.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
80
Rocky Face, Georgia
I would start looking at all the brake linkage first. Maybe you will get lucky and it will be sticking some where.
The diff oil should check where you check the trans oil as they are the same .
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
11
Richmond Va
Im with Bulldawg on this one, check the break linkage and take the wheel off and have a little looksee at the break drum. If you've ever did breaks on a vehicale the breaks on tractors are very similar.
tcbro
L185, Woods L59 mower, rear blade, L-225, Kubota FEL
Mar 10, 2010
49
Coatesville, PA
I've been noticing the same thing on my new-to-me L185. It even seems to be the same wheel. I'll be watching this thread closely. As soon as I get a spare hour (ha!) I'll pull my wheel.
Tom
traildust
B7610HST 4WD, LA352 FEL, Gearmore 2 Spool Top & Tilt Box Scraper
Jan 27, 2010
1,490
Phelan, California
spocialblend218, I just noticed you live in Hesperia :eek:
Glad to have a really local neighbor on here - and welcome to the OTT :D
scotrf
Kubota L2250 Ford 1100 FLseries TILLER HYD BOX BLADE PHD 5ft BRUSH HOG
Apr 21, 2010
Weatherford tx
not real familiar with this model , but i believe most similar. check the brake cam for wear or possibly rust causing it to stick in place.
