L245 3 point linkage problem
philkent
96
australia
3 point linkage wont go up under load Filter is clean Good pressure from pump.Orings replaced in lift cylinder..What to do next? At the moment the 3 point will slowly rise with high revs without load
hodge
Nov 19, 2010
2,859
369
Love, VA
Uplifter valve sticking?
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,130
933
Williamstown Ontario Canada
Before taking things apart try sending a private message to " rbargeron."
He owns and has owned a number of older L's plus is very well educated technically.
It may be an issue with the feedback rod but ask Dick
Dave
3,402
How and where did you measure pump pressure and what was the number?
3,402
We Took off the banjo fitting under the seat didnt measure the pressure but came out pretty strong
You need a pump discharge pressure test at that banjo or the pump outlet. That test hookup is a bit tricky to make.
Or we could just keep guessing.....
