L2000/L225 Rebuild and Restore, Pics inside!
CobraTom
L5030, L3430, L4310, L3410, B3030 , R510 currently..
Sep 19, 2011
126
Ontario
So I tumbled into the Kubota world head first but I am always up for a challenge and thoroughly enjoy everything about these tractors and how basic yet functional while compact they are. I do not think I would want a newer BX or B series simply because of this. Anyways..
I went on a 24hr road trip (12hr there, and 12hr back) after I purchased a L2000 near St. Louis for $1000. Tractor was guaranteed to run well, but had a lot of steering issues (which I naturally assumed and blamed the box for).
Here are the pictures of when I purchased it/picked it up.
On the way:
In the Driveway: (Next to my Ferguson TEA-20)
CobraTom
Sep 19, 2011
126
Ontario
On the way there, I stopped at a Kubota dealer and found a great deal on a L2040 plow (which is now for sale by the way)
CobraTom
Sep 19, 2011
126
Ontario
Good time to redo all of the wiring:
Removed the fuses and replaced with marine breakers: (while retaining the oem cover)
CobraTom
Sep 19, 2011
126
Ontario
After a lot of sanding, and a lot of coats of paint...
After some modifications (12V cig outlet, switch for rear lights) and steering box repaired:
Painted front grille, new top grille and replacement lights (From Princess Auto):
Awaiting new front LH spindle (old one was seized solid, another part of the "small" steering issue)
Let me know what you think! I know its a lot of posts, this has been over the course of the last week or two, and don't mind the mess in the shop, just moved to a new property and havent really had the time to make it home. :)
tcbro
L185, Woods L59 mower, rear blade, L-225, Kubota FEL
Mar 10, 2010
49
Coatesville, PA
Well Tom, I diagnosed your steering problem with the first picture......there's no steering wheel!!!!
You certainly like to jump in with both feet, don't you. $1000 is a good price and your restoration looks great. I hope you took care of the steering issue before you put too much time and $$ into it.
I'm currently putting my L-225 back together after replacing the reverse gear and the clutch.
Good luck with your orange tractor and keep the pics coming.
Tom
CobraTom
Sep 19, 2011
126
Ontario
Tom
Yep. I had a incorrrect steering wheel (wrong spline), bad steering box (typical bearing gone fishin'), a bad tie rod, broken LH steering arm, and a seized/pitted spindle.
Luckily I was able to put it together with a combination on new parts (bearings, seals) and used parts, for under $350.
Good luck on your project! My next one is installing the loader.
tcbro
Mar 10, 2010
49
Coatesville, PA
Tom
I'm not sure the L2000/L225 pump has enough flow for an FEL. Mine has a separate hydraulic pump that is driven off of the front of the engine and it has it's own resevoir on the back, right FEL frame upright. I think most FELs require a minimum of 5 gpm and I think the pump on my L225 is down in the 3-3.5 gpm range. Something to look into.
Tom
CobraTom
Sep 19, 2011
126
Ontario
FEL is on the tractor, it works great.. it is a bit slow, but thats the only restriction 3.5GPM has on the FEL, pressure is right at 2000psi, so the strength of the FEL has not changed.
I am comfortable with slow for now as I learn to operate the FEL.
mattbatson
86
Deltona, FL, U.S.
great thread
I plan to restore mine also, just more slowly over time.
plan to keep my B1750 till I die, and pass it on to my son...
right now we are just working on mechanical stuff, maintenance, and learning about tractors...
and everything I touch gets either a new part or some special attention, as we want this to be a like new tractor in a few years.
aquaforce
L245DT FEL, JD450 Track loader, 5' scrape blade&mower, 5x10 trailer, Dump truck
Apr 22, 2009
757
Stockbridge, Ga. USA
Very nice buy. I would do that in a hear beat.
Great pics. We love pics here and it was great to scroll through them all. Your making the orange proud. :D
I have pics in my "L175 sheet metal work" thread. http://www.orangetractortalks.com/forums/showthread.php?t=1533
My tractor was a roll over so there was a lot of damage to repair. I used the tractor as it was till the head busted then went through it all.
My steering wheel was bent badly so I got a new one. The steering gear box was empty but seems ok after filling it up and working it.
Currently I have turf tires but I would like to get an AG set for mine some day. I like the benefits of both so it is hard to settle with one wheel type.
SCVandy
L225
Dec 31, 2013
12
Waverly, NY
What do you call the original flat metal fuses that were in the dash fuse box with the grey cover? I need two 5 amp fuses and cannot find any info on them. This is the picture of the fuse box you posted. I need fuses or I have no lights.
