L175 No 3 point lift
brown10
L175
Aug 4, 2011
23
Lake Wales, Florida
Greetings,
I was using a 4' rotary mower with my L175 over the weekend. I have lost lifting power with the 3 point. Fluid level is good. I took the mower off and I can lift the 3 point arms up & down without resistance. I may have damaged something by descending down too steep a grade & put the 3 point in a bind when I leveled out on flat ground at the bottom of the hill. The issue seems to have started then. I have a schematic parts manual. Wonder if you folks might have an idea of what I probably did. :eek: Thanks and Happy Thanksgiving! - Jerry
aquaforce
L245DT FEL, JD450 Track loader, 5' scrape blade&mower, 5x10 trailer, Dump truck
Apr 22, 2009
757
Stockbridge, Ga. USA
3pt arms fly up normally with no problem so the articulating with the mower could be coincidence even though that was about the time of the problem.
kubotasam
Apr 26, 2010
1,200
125
Alfred Maine
Where is the filter/screen on a 7100?
On a gear drive B7100 the filter is on the right hand side (sitting on the tractor). It is part of the banjo bolt that holds the hydraulic suction line to the transmission case. It is #4 in the attached picture.
