Hello all,
I could use some troubleshooting tips on my clutch/trans. When it gets warmed up, 30-45 min, I cannot get it to go into gear. So I drained the HYD fluid, cleaned the filter and no change. I split the tractor, replaced the disc, clutch, and release bearing and no change. I can start it in gear, drive it but as soon as I attempt to shift gear nothing but grinding. I'm not a mechanic so anything would help. Thank you
