L 3400 , jerky 3 point hitch
bibman1951
Kubota L 3400 HST
Oct 21, 2017
14
Cedar Lake ,IN.
Good quote ,especially mistakes involving injury . only takes a second to get hurt , takes a long time to heal ,if ever . Safety First .
bibman1951
Kubota L 3400 HST
Oct 21, 2017
14
Cedar Lake ,IN.
CaveCreekRay ,Thank you for your reply's , and the pictures . Its helpful to be able to visually see it . now I have to do some home work . I'm feeling hopeful that I may be able to fix this thing . Thanks Again
bibman1951
Kubota L 3400 HST
Oct 21, 2017
14
Cedar Lake ,IN.
Teg , thank you so much for those diagrams . Those along with the pictures Sheepfarmer sent are making me feel hopeful .
Oh , I'm sorry that was CaveCreek Ray that sent the pictures . I'm felling hopeful that I may be able to fix this problem . Don't know when I'm going to get around to working on it , I'll keep you posted
sheepfarmer
Nov 14, 2014
4,438
678
MidMichigan
Hello sheep farmer , I clicked on the link about the 3 point control valve you sent me, but i couldn't get it to come up . Could you please check to see it is correct , I would appreciate it . Thanks
It works ok for me, but I edited it so it comes up on page 1 of Ray's thread in case that helps. But as noted above many of the photos are gone, so you can try to piece the text of the thread with the photos he has added here.
CaveCreekRay
Jul 11, 2014
2,631
106
Cave Creek, AZ
I believe the same thing TEG mentioned...
Kubota isn't going to replace an expensive part if an adjustment is all that is necessary. My valve was worn either due to maladjustment on installation or a defect in the valve during manufacture -or design. Some have mentioned an improved valve used in replacement but I cannot confirm that as my replacement had the exact same serial number as the original.
If you bought a new valve and then measured all your linkage positions before breaking the defective valve down, it should be a simple case to reset the new valve to the same clearances. Getting to the valve couldn't be much easier as its under the driver seat on the "toilet tank lid."
Be sure and cover the rear end with foil or a towel to keep foreign bits from entering the rear end.
coachgeo
Nov 16, 2012
2,459
37
Southern OH
Kubota isn't going to replace an expensive part if an adjustment is all that is necessary. .....
Not "always true" when you take into account labor for either job. Granted if new one has to be adjusted anyway then most likely they will start with adjustments to existing one.
