Kubota T1670 Help
Xi Bowhunter
T1670
Apr 20, 2017
Whitesville
I am needing an oil filter for my Kubota T1670. I don't have a Kubota dealer close to me, so I was hoping I could find a Fram filter that would fit my mower. Does anyone know what Fram filter would fit on my T1670?
Also, how much oil and what type will I need for the oil change?
Thanks for any help!
cwcnst978
North Carolina
Not sure where you are. But Parker farm supply is pretty knowledgeable in Kings Mtn. N. C. They sell Knots and have good parts dept. 704 259 6100 if not a compatible filter may order you one
Sent from my N9519 using Tapatalk
Xi Bowhunter
T1670
Apr 20, 2017
Whitesville
I'm in Kentucky.
I know the mower has a screw-on type of filter, and I was hoping someone could help me find an automotive-style equivalent like a Fram, Wix, Purloator, ect that would fit my mower.
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,189
168
Hardisty, Alberta
These filters fit your mower (it has a Kohler engine) Us any good grade automotive oil. multigrade ok, suggest 10w30?
http://www.oilfilter-crossreference.com/convert/KOHLER/1205001S
Xi Bowhunter
T1670
Apr 20, 2017
Whitesville
Are you sure about that list?
I looked up the part number on Kubota's website and got a part number E7194-32110
That cross referenced to a Fram PH6016, PH3614, and PH7575. But on your list, it cross references to a Fram PH8172. Now I have no idea what filter I need. I'm going to have to see if there is a number on the filter that is on it I suppose.
eserv
May 27, 2009
2,189
168
Hardisty, Alberta
The ph7575 is about an inch longer than the ph8172, either will work
lugbolt
ZG127S-54
Oct 15, 2015
5,420
2,113
Mid, South, USA
It's just a run-of-the-mill Kohler, CH16S I think it was?
Either way, they use the same filter that most of the air-cooled Kohlers used, which is available for any bad boy Kohler-powered mower, if you have a tractor supply company close they have them. 1205001-s IIRC is the kohler part number, may cross over to an automotive filter.
Funny thing. I was "junkyarding" a while back and the particular yard I was at had the cars all marked on the quarter panels what was wrong with them. Trans, Engine, wreck, whatever. I was looking at a bunch of engine failed cars/trucks and a big majority of them had fram filters. I found that odd. Big ol' orange filter sticking out like a sore thumb. I switched brands immediately. But I also understand that sometimes in a pinch you have to do what you can.
Here you go:
