Kubota Starting Issue
ranger4327
L3800
Apr 2, 2012
20
Northern Maine, USA
Kubota L3800: for about a year, tractor would occasionally have difficulty starting. When key is turned, a clicking sound (and no start) would occur from either starter or solenoid. After a few tries, tractor would eventually start.
Today, tractor started with no issues. Shut tractor off for approximately one minute. Turn key to start and nothing. No clicks, no crank, just ignition lights. Turned key to the left and glow plugs seem to work. After a few attempts, clicking sound returned when key was turned. Tractor eventually started after quite a few attempts.
Has to be electrical.... Starter, solenoid, wiring, something else?
torch
Jun 10, 2016
2,702
924
Muskoka, Ont.
Sounds like a loose or corroded connection.
2,796
Yup....
the fact that the battery has enough to spin the engine says it is not at fault.
Take the wire from the neg post off......then the pos side off, clean the pos first and where it goes back to the starter if possible.
then take the neg off the frame/engine and clean it - then clean the first connection at the battery. While doing all of this, look carefully at the cables, especially under the insulation.
Also - check the pto safety switch - while turning key when it will not turn over, move the PTO lever. Yours might have a seat switch too - bounce a bit while turning the key.
Sounds crazy......but one of those is going to be the problem more than likely;)
allencf
L3800
Dec 4, 2017
Bladenboro
Had the same same with my 3800, removed the guard from the HST safety switch and adjusted the switch... cranks now each time ..
thebicman
B2601 + BX2755HD + 50" box blade
Feb 2, 2017
337
100
Ottawa, ontario
From the video it sound like a poor ground connection. As stated clean all your connections well.
MikeyA
2016 B2650 FEL and 60"mmm,1998 B2400 MMM FEL(sold!) BB 4ft BRUSH HOG
Mar 6, 2010
150
West Central Illinois
Check your connections at starter solenoid for corrosion. I had a similar issue with my B2400, after cleaning the spade connectors, it worked like new!!
