I'm betting I can make this thing fit m B2410 - anybody have anything remotely close to experience?
It has the towers and what looks like most of the mounting portion of the subframe. I'll fab up everything else to ensure it's tied together and the load is distributed across as much of the frame as possible.It's for an earlier generation of Kubota, but I don't see why it can't be done. Do you have the towers too, or just the arms? You'll need a subframe that runs the length of the underbody to tie everything together, and a crosspiece from that subframe will support the towers, with braces to the front.
If you can get information on the proper subframe for that tractor (attachment points, etc) you can replicate it. Good luck!It has the towers and what looks like most of the mounting portion of the subframe. I'll fab up everything else to ensure it's tied together and the load is distributed across as much of the frame as possible.
I can print the exploded parts view from Kubota and get pretty close to the subframe design of the LA 351, which is the original FEL specified for my tractor. Will be a project, but having a neighbor that owns a welding shop and who is pretty darn good at what he does kind of helps.If you can get information on the proper subframe for that tractor (attachment points, etc) you can replicate it. Good luck!
