Kubota L4630 - Exhaust Manifold
lourent
Kubota L4630
Jul 9, 2019
24
Pretoria
Good day all,
The last thing I would like to do on my project is pull the motor apart. I took the Exhaust Manifold of today for painting. What I noticed was that the Port closest to the Clutch was very caked up. It looks like oil build up, but may also be un-burnt Diesel. I did start the motor before tearing the tractor down and it sounded fine. I'm no mechanic, so I may be wrong. The other three ports look fine. This tractor was standing for an un known time. Any ideas, or should I take the top off?
Thanks again and regards Thys.
2,825
Before "popping the top off" - do a compression check - that will tell you a lot with those numbers.
You can a "cheap" one at harbor freight.
200mph
Mar 3, 2017
1,228
61
PA
x2 on the compression test suggested above.
If low, perhaps run a leakdown test to assess if valve or rings.
