My L3400 won't start. When I turn the key, nothing happens - no clicking, no cranking, nothing. All the lights are functioning, so the battery doesn't seem to be the problem. I tried jump starting the battery just in case - no success there.
This is a manual model, so the only safety switches (I think) are on the transmission range selector, the PTO, and the seat. When I move the range lever to Neutral, I hear a solid click in the engine bay, which I believe indicates the switch is working. I think (just think) this click also indicates the other switches are functional.
I tried jumping the terminals on the starter. I got sparks and the wire I was using for the jump even started to heat up, but no crank. I'm thinking this probably means the starter is bad. It's really tough to jump between the terminals on this starter - the terminal on the engine side is covered by a rubber boot that is nearly impossible to remove. When I get a chance, I plan to pull that boot off as much as possible and try jumping again.
Any other suggestions? Many thanks!
