So here we are in 2020 and my 2004 M9 has been exhibiting some interesting quirks. The ac stinks for one and the airflow from the vents has been getting less and less but cooling power is just fine, just hot enough volume and it has a distinct odor about it so...
I removed the roof. I've removed it before. Kubota installs all the climate control mechanicals up top on my unit (I understand they are now under the seat), enclosed there. Mine are not.
Last time I removed the roof (6 years ago), I lined the inner roof with Reflectix foil-bubble foil insulation so the climate control wasn't fighting the heat constantly (the roof is not insulated at all and the sun beating on it, really heats it up). it helped but as I said, airflow is becoming less and it stinks so..
I partially removed the upper unit cooling heating cover to gain access to the evap. The way it's designed, it's impossible to remove entirely without breaking the hard lines and removing the heater core which entails draining the coolant so I removed all the screws and bolts and propped the cover open enough so I could see the evaporator. It was basically solid mass of coagulated dust and dirt, no winder it stunk and no winder the airflow was reduced, don't see how anything could get through that mess.
After propping the cover up, I took a spritz bottle with purple ZEP in it and soaked down the evap and let it sit for a while. Then I took my pump garden sprayer with warm water in it and flushed the coil. Did that 3 times, making sure the stuff was draining out of the condensate tubes under the tractor, which it was and it was nasty. Took 3 applications to get the water to run clear. Once I had clear water, I buttoned up the shroud and replaced to roof but I also replaced the old sealing gasket which was shot and letting dust in.
I'd never cleaned it before. That won't happen again. I'll be cleaning it at least every other year from here on out.
Was talking to my good friend down the road who owns a huge seed operation and has a fleet of large cabbed JD's and he told me they do that every spring. Change the fluids and clean out the ac units.
I won't be lacking that aspect again. It not only smells good now (I changed the intake filter on the roof as well, but it blows hard and cold, just like new.
He was surprised when I told him I never cleaned it. His comment was "I'm surprised it even worked at all".
Little heads up if you have a cabin unit with ac....
FYI, the roof is secured with 10 threaded screws. Every other screw secures the roof and the roof screws are quite a bit longer that the others so if you remove one and it's short, the next one, either way will be a roof screw.
I imagine the underseat unit suffers the same fate, dust loading up the evaporator but I don't know the cleaning procedure on that.
