The M9000 tractor bounces or rocks back and forth going down the road. Is there a way to check the right rear bearing if there is a bearing. It feels like a knot on the right rear tire but I had new tire installed and it still does it.
Is there fluid in the rear tires?
Have seen it where the fluid will start going around with the tire at road speed (versus the "air pocket" staying on top), and cause all sort of stuff like a side/side wobble or what feels like an egg-shaped tire.
Also have heard (never seen firsthand) stories of folks losing control if the hop gets bad enough. So whether this is true, throttling down when the wobble starts is probably good advice.
Mine does it on a paved road at high speed. My tire is somewhat out of round or has a twist in the tread. It is worse on a cold tire, but I seldom run it on the road other than when making hay. It is not a huge issue for me so will run it as long as I can.The M9000 tractor bounces or rocks back and forth going down the road. Is there a way to check the right rear bearing if there is a bearing. It feels like a knot on the right rear tire but I had new tire installed and it still does it.
This past summer an Amish family near me had probably the most tragic accident ever in my county. A small utility trailer loaded with 9 people was being towed by a very old tractor on a very steep road when control was lost. Wife, 3 kids and a nephew were lost. In addition, there were severe injuries to others.Hokie mentioned it.....probably not related to the OP's problem, but when a kid my grandfather and father always warned to never take a tractor out of gear on a hill.
If you've got a couple ton of hay or silage in a wagon behind you, bad things can happen, and real fast. Happened to a couple of my friends.
Holy smokes, so unfortunate and sad. True, Amish don't talk much.....This past summer an Amish family near me had probably the most tragic accident ever in my county. A small utility trailer loaded with 9 people was being towed by a very old tractor on a very steep road when control was lost. Wife, 3 kids and a nephew were lost. In addition, there were severe injuries to others.
The exact cause may never be known, the Amish donāt dwell on such things. One theory is that model tractor free wheels in low range but will hold back in high range, opposite what you might expect.
