Hi all!
I'm a newbie in this forum with a classic B7100D that is grinding when changing the gears.
The symptom varies: when cold the RPM is slow and the gears change with little grinding, but once it warms up, the RPM goes very high to the point that to change gears, I need to shut the engine off.
The mechanic's diagnosis is that my gearbox needs repair, but with my limited experience I believe I need first to address the high RPM problem. .
Questions for your expertise!
Could the increase in RPM be the culprit?
If so, is the fault in the governor, in the diesel pump, or in both?
If so, can I adjust them or overhaul them if I get the needed parts?
Thanks ahead!!
Aris
Thanks ahead!!
Aris
