Keep breaking mowing blades
jarhead74
B7100 and 60 in. belly mower
Jun 12, 2012
hAMLIN, wv
I have a 60" belly mower. The gearbox will not stay tightly secure. Would this cause my middle blade to break? Do you have any suggestions on how to keep it tightly secure?
Thanks,
Jarhed74
hodge
Nov 19, 2010
2,859
368
Love, VA
What do you mean that it won't stay tightly secure? Are the bolts backing out? Is the deck flexing where the gearbox mounts? If you are dealing with blades breaking, I'd assume it has to do with a loose gearbox.
Bluegill
Jan 11, 2012
1,560
Success Missouri
Why wont the gear box stay tight? Holes striped? Need new bolts? Lock washers? Lock Tite?
And like Hodge said, that is likely your blade problem.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
I'm thinking at this point you might have struck something hard with the deck and tweaked the deck a little bit and put a bend in it some where. Check and inspect the deck and see if theres a crack in the deck or a bend somewhere near the gearbox.
jarhead74
Jun 12, 2012
hAMLIN, wv
Thanks, I will try new bolts and Lock Tite>
