I personally helped a friend install a FEL on a B7100. This was years ago but some details are firmly fixed in my mind.
I wish we had the details including part numbers which Whitetiger has provided you.
The B7100 WSM, available free on Kubotabooks.com, has an excellent color illustration of how the new outlet block cover is to be connected to a new valve. Presently, the B7100's only hydraulic system pressure relief valve is at the 3 pt hitch end of the tractor.
Kubotabooks.com
Using the new outlet block cover to install a loader valve between the main pump and the rear of the tractor cuts the only pressure relief valve out of the circuit and exposes the main pump to severe damage.
The new loader valve must have its own pressure relief valve. Most new valves do but it is a critical part of a successful installation.
In this illustration the relief valve marked with a green box is exterior to the new valve but this is just for explanatory purposes.
A common mistake owners make when buying a loader valve is to buy the one with the most gpm rating. This is the opposite of what you want to do and will make controlling your loader very difficult.
The B7100 has a gpm rating of almost 3 gpm which is small.
Recently a forum member was installing a new loader valve. He made a decision which will be valuable in the future. His new valve had the two common spools controlled by a joystick but as part of the same valve body was a third spool controlled by an individual lever. This third spool was provided to control a future grapple.
Most hydraulic valves are not designed to tolerate high pressures on their TANK port. You should be using a power beyond port for the oil being fed from the new loader valve back into the hydraulic system going to the rear of the tractor. PB is usually a $25 option you need to buy when you buy your new valve..
This is the 3 spool valve the B2400 owner had ordered.
3 spool valve
These are images of the PB sleeve. They are unique for a particular series of valves in this case a Badestnost 40 series.
A plug in the new valve body is removed and the PB sleeve is screwed in. The sleeve creates an additional port on the valve body.
Forum member Win22wrf, who has a B7100, has suggested this 8 gpm valve in the past.
Prince valve
If at any time during your project you are uncertain, dont try something to see if it will work. This is not a good strategy with hydraulics. come back with questions until you know exactly what you need to do.
Dave
