I have a B7800 and had a split in the sidewall of one rear tire. Tractor is about 10 years old with 482 hrs. After checking on a few options I decided better bang for the buck to replace the tire.
The new tire came mounted on a new rim and after installing it I realized it was a fair amount higher than the other rear tire. More wear apparently on the original tires than I thought.
So question is, am I going to mess something up with two different diameter tires on the rear? Both are 13.6-16 tires but the wear on the other one sits the tractor noticeably lower on that side.
Can I change the air pressure in the tires to try and equal the same height or do I need to install 2 new tires (scary thought as the new one set me back $600 CAD dollars)
Also, after installing the new tire and torquing the wheel nuts I checked the air pressure which calls for 14psi on the rears and 22 psi on the fronts. The new tire had 28psi!!
I dropped the pressure to 14psi naturally but was curious if the reason they shipped it with that much pressure was to insure the bead kept it's seal during shipping. That's only an uneducated guess as I'm a newbie (1 year) tractor owner.
Any knowledgeable people have suggestions/opinions on this?
Thanks in advance for any suggestions, etc.
Keith
Keith
