J jim boy New member Equipment Kubota l3710 Feb 9, 2022 6 0 1 71082 Jan 8, 2023 #1 My l3710 will not cut motor off by the switch ignition switch
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 35,139 10,354 113 Sandpoint, ID Jan 8, 2023 #2 Stop solenoid, stop solenoid timer, blown fuse? Quite a few possibilities. Very uncommonly would be anything to do with the switch. Reactions: 1 user
L lugbolt Well-known member Equipment ZG127S-54 Oct 15, 2015 5,506 2,215 113 Mid, South, USA Jan 8, 2023 #3 fuse wiring solenoid switch ground controller/timer all are possibilities get your service manual out and go through the diag process kubota outlines it fairly well once you get past the jinglish Reactions: 1 users
J jim boy New member Equipment Kubota l3710 Feb 9, 2022 6 0 1 71082 Jan 9, 2023 #4 jim boy said: My l3710 will not cut motor off by the switch ignition switch Click to expand... Thanks everyone for the help. I found the fuse 15 amp was bad. Working now thanks.
J jim boy New member Equipment Kubota l3710 Feb 9, 2022 6 0 1 71082 Jan 9, 2023 #5 Thanks everyone for the help. It was a bad 15 amp fuse.
