I can walk faster than my L4701
MDB72513
L4701 tractor
Mar 25, 2025
Central Arkansas
Tractor loses power when driving up slight inclines (think 1 foot drop over 20 in length) in normal operation; simply comes to a stop and engage 4 wheel drive to move. It cannot pull a 5 foot rock rake, let alone a 5 foot mower unless it is in 4 wheel drive. I’ve heard that it may be the clutch, but that answer came with an lack of confidence.
I’ve done the following;
New fuel filter and water separator screen.
Filled/topped off hydrolock fluid.
Any help would be great.
Thanks,
2,897
hydrolock? I hope that was a typo - you mean Hydraulic?
And this is a HST model not the synchronized shuttle version?
IF you have HST - you in high range when this happens?
JasonW
569
336
Al
Going off your first post, it will move uphill only in 4wd? But not in 2wd?
BAP
Dec 31, 2012
3,058
1,175
If it moves in 4wd but not 2wd , sounds like something broke in the rear end. Bad clutch would not pull in 4wd versus 2wd.
BX23-S,57 A-C D-14,
5,871
if this is the rear end, could broken #070 explain it ? never seen 'keys' in a diff,so curious as to why they're there. If it drives fine in 4wd(pull a load) doubt it's the clutch.
9,581
There are quite a few parts that will make the rear no have power, could be everything from broken axle up to the coupling to the differential and everything in between!
whitetiger
Nov 20, 2011
3,313
1,732
Kansas City, KS
Thanks,
Does the tractor pull ok with the front axle engaged?
