I-Beams
Kubota_Man
BX24, Rear blade, Front blade, Snowblower, 54" MMM, Box scraper, Landscape rake
Dec 25, 2010
953
Kellogg, Idaho
Does anyone know how to figure how to calculate the size of I-Beam I would need to span 12' and support 1500lbs in the center with no overhead bracing? I am not too concerned with metal type just don't want to spend more than I have to.
3,852
Hey Dennis,,, Whats that green thing in your barn???:D
cabu
Kuno B1-15 (B1502DT)
May 24, 2009
736
Germany, Oyten
Normal construction steel -> 235(N/mm²)
I-Beam (DIN 1025): Hight 80mm, width 42mm -> Wx=19500(mm³)
Example:
4 meters long and supported at the ends, load in the middle.
Fmax=([Steeltyp]*4*Wx)/l
Fmax= (235(N/mm²)*4*19500(mm³))/4000(mm) = 4582.5 N
Maximum weight in the middle = 4582.5 (N)/9,81 (m/s²) = 467 kg
Questions? :D
der carl
ps
You need the shape of the I-beam to get the value of the Wx and the type of steel for the strength (N/mm²)
I am just a german engineer and I don't know the american I-beam standarts... :eek:
What I have found is:
12' -> 3,6m
1500lbs -> 683kg
weight*g*l/4/[Steeltyp]=Wx
Wx= 683kg*9,81[m/s²)*3600mm*4*235[N/mm²)
Wx= 22673[mm³]
-> I-Beam standart size minimum IPE100: 100mm x 55mm (32000[mm³])
I-Beam
3,852
CABU thats pretty indepth,, now if you would please put that in to coal miner talk:D
cabu
May 24, 2009
736
Germany, Oyten
Open a beer, wait a little bit and try again. It is high-school stuff. You only have to understand that the shape (Wx) and the way it's stressed is importend. :)
Kubota_Man
Dec 25, 2010
953
Kellogg, Idaho
What exactly is it you're trying to accomplish with an I-beam over a 12 foot span?
I want to be able to span center rafter to garage door and put a rolling hoist on it. Both front and center rafters have a 2000 lbs pick points. I hope to be able to use the that span at any point inbetween.
Example:
Questions?
der carl
ps
12' -> 3,6m
1500lbs -> 683kg
Wx= 22673[mm³]
What did you just say????????? I reconize that there is english and numbers in this, however can you explain this in a language that a hard rock miner and an Army guy can understand please :confused:
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
I helped a neighbor put 12'' tall I-beam in his barn that was about 12-15 feet wide and he put a hoist on his beam and lifted up all sorts of stuff...
smog
B7200HST, diy 3pt forks, diy 3pt blade, 3pt mower, diy hyd rotary broom
Oct 23, 2011
56
Montreal
www.northernliftgates.com
Example:
I-Beam
THANK YOU, was looking for that formula.
3,852
YA know I love engineers really I do. They are some of the most friendly help you out of a jam kind of guys I know. One young man in the District Office is a” I hope I have this right “
Geological - Hydriodic Engineer he works with water and earthen dams at mine sites.
A great kid, he hunts, raises field dogs, fishes, and loves his 2 sons to pieces. The only problem with Craig is,, don't ask him what time it is,, cause before you get the answer he tells you how a watch is made and why it works,,;)
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
Don't feel bad Skeets. My Son is in 7th grade and my daughter in 1st. They no longer have simple adding, subtracting, and multiplication any more. They have wierd, strange names for this now. It may work about the same and you end up with the same answer but the process is totally different. Makes me feel dumb. 2+2=4 still works for me but the kids now days seem to go all the way around the world to get the same answer.
cabu
May 24, 2009
736
Germany, Oyten
Don't feel bad Skeets.... Makes me feel dumb. 2+2=4 still works for me ...
But 1+1=1 !:cool:
If you dump one sandheap on another you get one. Bigger, but one! Computers calc that way, boolean algebra.
YA know I love engineers really I do....the answer he tells you how a watch is made and why it works,,;)
They always try to give you the fishing rod instead of the fish. So you don't come a second time with the same kind of question... :D
And by the way, kubotaman got his answer (only a metric one)
:confused: :confused: :confused:
I give you the answer!! ;)
I believe the american construction steel for simpel standart constructions is nearly the same like the germans.
So I gave you the dimensions of the I-Beam you need: 4"x2" with a steel thickness of the middel one (web) of 1/6" and the beam top and button (flange) in 1/4"
At that webpage it looks like it is the I-Beam typ S4x9.5
Have fun and don't walk below hanging tractors...
der carl
Kubota_Man
Dec 25, 2010
953
Kellogg, Idaho
Ok I talked to a local engiering firm and he said W8X15 with a 50ksi (what ever that means). How does that compare to what you said of S4x9.5 Cabu????? I'm all confused :confused::confused::confused::confused:
cabu
May 24, 2009
736
Germany, Oyten
What I have found:
Strengthness of steal: 50 ksi = 344 N/mm²
Shape W8X15 ~ IPE200 -> Wx=194000 (roughly)
Fmax= (344(N/mm²)*4*194000(mm³))/3600(mm) = 74151 N
Maximum weight in the middle = 74151 (N)/9,81 (m/s²) = 7558 kg (16662lbs)
[Weight of the beam would be 80 kg (178lbs)]
The maximum weight of 16662 lbs is when the I-beam starts to bend permanent. The risc-faktor of 11 (16662 / 1500) is maybe a litte bit to much... ;)
Think by your self: 12' and 1500lbs in the middel! That does not need an I-beam of 8" x 4". Imagine how big it is.
My opinion is that you should install an I-beam that bend before a force is damaging your barn. Your supporting points can stand 2x 2000lbs. The I-beam should start to bend below that. It's cheaper to buy a new beam than a new barn. My opinion.
carl
Kubota_Man
Dec 25, 2010
953
Kellogg, Idaho
I do agree that something should start to show stress (I-Beam bending) before I reach the max capacity of the building. Although while I am good with math the calculations of how to figure what I need and or should have excapes me. So I need to ask smarter folks like those here on OTT and local folks who are in the know.
So how does S4x9.5 compare to W8X15? Is there a differance as far as Metric and SAE? What is the weight limit on both at the center of a 12' span?
I don't want to see this happen to my Kubota's house ;)
http://nature-photography.ca/photos/palouse-washington-collapsed-barn
cabu
May 24, 2009
736
Germany, Oyten
What I have just found:
S4x9.5
Elastic properties Sx 3.39 in³
Plastic modul Zx 4.04 in³
I guess, elastic will mean it will bend back and plastic will mean the bend will be permanent.
Shape S4x9.5: Sx 3.39 in³ * 25.4³ -> Wx = 55552 mm³
Fmax= (344(N/mm²)*4*55552(mm³))/3600(mm)/9,81(m/s²) = 2164 kg (4770lbs)
Maximum weight in the middle!
[Weight of the beam would be 51 kg (112lbs)]
Your poles can support 2x 2000lbs = 4000lbs -> 1814 kg
There is a problem of 350 kg. Don't damage your barn.
If you take the next smaller I-beam S3x7.5 the Sx is 1.95 in³ and the maximum weight will be 1244kg (2742lbs) and it's weight will be 40kg (89lbs)
The W-shape I-beams are all to strong.(Book of Steel)
Barn 4000lbs
S4x9.5 4770 lbs
S3x7.5 2742 lbs
'Life is like a box of chocolates you never know what you're gonna get' :D
der carl
ps
I have just checked your answer regarding what you want to do. If you put the load not in the middel but at the end next to the rafter, it shall not be more than the 2000lbs of the supporting point!!
