Hydraulic oil in engine
CRETE4U
L3010 HST with loader
Jul 12, 2012
Dunnellon, Florida, Marion
Hi all. I'm new here and looking for a little help. My tractor is an L3010 HST with loader. I bought it new in 2001 I think. I use it in concrete construction. My problem is hydraulic oil getting in the crankcase. Is the hyd pump on the engine on this model? I ordered a WSM, but was hoping for some help in the meantime. Thanks in advance
Bluegill
L3750DT Shuttle, L3800DT FEL both
Jan 11, 2012
1,559
Success Missouri
Never heard of this problem? On most of these tractors the hydro pump is bolted to the back of the injector pump, which is bolted to the side of the engine block. I guess if a seal went bad in the hydro pump, it could pump oil into the engine?
How do you know hydro oil is in the engine oil?
kubotasam
Apr 26, 2010
1,211
136
Alfred Maine
If the seal on the pump is bad it defiantly can put hydraulic oil in the engine.
Breeze
L3700, Box Grader, 60" Bush Hog, Rear Grader Blade, York Rake, Boom Pole.
Dec 24, 2010
149
Virgin Islands
and the only thing worse than this or fuel in the crankcase is coolant. Any of the three will ruin your engine.
Theekillerbee
273
Pleasant View UT, USA
I'm not familiar with the specs on your tractor, however my B8200 had a seal go bad in the front of the hydraulic pump. This allows the higher pressure oil to enter the crank case. The first time it happened, I just replaced the seal, that lasted about a year and it went out again, so I dropped the extra cash and just replaced the pump. Mine is a bear to get out, so I wasn't going to change the seal every year. I'd suggest just buying a new pump and do the job once.
hodge
Nov 19, 2010
2,960
537
Love, VA
How much have you run it with hydraulic oil in the crankcase?
CRETE4U
Jul 12, 2012
Just to let you all know. I put a new seal in the pump this weekend, also new o-rings and seals inside the pumps. Everything is back to normal. I hope it lasts more than a year. Thanks to all who posted.
