Hydraulic hoses
BarryB
L2600DT & B7100
Jan 24, 2018
Magnolia, Texas
My name is Barry, I have a L2600 with a front end loader. I need to know where the 3 hoses that go from the loader joy stick box back to the side of the transmission. It’s a 9210 control box. Or maybe some one can tell me where I can get a diagram on the hydraulic lines. Thanks
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
Do you have an operators manual? They generally have the points marked in the manual. What model loader do you have?
I can't see an ops manual on the net with a quick search, if you don't have one, send North Idaho Wolfman a message and see if he has one squirreled away.
11,009
This should be what you need to know:
If you need more info just ask. ;)
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
Not sure if it's because of your single post status Barry or something else, but I can't reply to your private message as it says you have exceeded your message limit?
BarryB
L2600DT & B7100
Jan 24, 2018
Magnolia, Texas
I got half of my problem fixed. Any advice on why my loader will go up & down but won***8217;t dump or turn up?
11,009
Does it have Quick disconnect on the hoses to the loader cylinders?
Could be one is not seated completely or is bad.
Swap both sets of hoses from lift to roll:
If three issue moves from roll not working to lift not working it's a valve or valve side disconnect issue.
If the issue stays with the roll then it's a line side disconnect or cylinder issue.
