HST noise
brayhaven
B2400
Sep 18, 2016
North Florida, USA
Just got my first Kubota. A 99 B2400 4wd HST W/600 hrs. Love it. But the hydraulics pump makes a lot of noise. Never had a HST tractor before. Is this whining noise that gets louder as you apply power (speed etc) normal? Seems louder than the engine at times. Everything works fine, plenty of power. Just need a little info.
Thanks,
Great site here!
Greg
yamatitan
L3901
Jun 28, 2015
38
Louisiana
Most likely normal especially on the smaller tractors. But just to be sure just the hydraulic fluid level they can be even louder when its too low.
4,432
I know the whine seems to be inherent on the small tractors, but like he said check the fluid level,, and your next fluid change use the SUDT 2 it makes a world of difference in the noise,
7,084
These guys are correct. If you don't know the service history, change the fluid so you have a baseline service interval. From experience, I too strongly recommend SUDT2, like skeets said.
I changed mine early, and the new stuff took a good part of the whine away.
Also, make sure you're using enough RPM. Mine can be noisier if I don't have enough throttle, especially in high-range.
brayhaven
B2400
Sep 18, 2016
North Florida, USA
Thanks folks, No idea of the maintenance history. I changed all the other fluids, coolant, filters etc. Was planning to do the Hydraulic fluid next. The same SUDT2 in the front axle too? Are Kubota OEM filters the best?
I see it holds a total of a little over 3 gals. Never was able to get the full spec'd amount in anything, due to some staying in. Will the 2.5gal jug be enough for a change? Is there a Good place online to get the stuff? or just try to find a dealer??
Thanks again for all the "orange" expertise.
Had to sell my old big Massey due to knee surgery on the clutch knee. This HST Kubota is sure easy to operate.
Greg
2,897
"The same SUDT2 in the front axle too? Are Kubota OEM filters the best? "
yes - you can all around - I would use K filters, and I would use the SUDT2 also
MikeyA
2016 B2650 FEL and 60"mmm,1998 B2400 MMM FEL(sold!) BB 4ft BRUSH HOG
Mar 6, 2010
150
West Central Illinois
Make sure you check the suction strainer on right side of transmission. It is just a stainless mesh tubular screen, but if never cleaned, it could have a lot of debri on it.
gravelman
Kubota 2650
Nov 21, 2016
22
WESTMORELAND
i recently bought a brand new K 2650 it is very whiny especially when im driving down the road and up a hill, the noise kicks in real bad.. and i have a factory cab any suggestions?? can you tell me more about this other fluid i see is being talked about..thanks alot
9,579
You may need to add sound deadening to the cab.
SUDT2 is Kubota full synthetic hydraulic fluid, costs a ton, but most have said there was a dramatic drop in noise in the HST when they switched to it! ;)
