I have a B6000 with the auxiliary belt driven pump mounted to the front of the engine and I am curious if there is a way to turn up the psi on it some how. I can usually lift just fine but it won't power down very well.
Agreed. All things the same, psi to the cylinders should be the same in and out. So, something else is different.Being that the problem is on the down and not on up, I highly doubt it's a pressure issue, it's either a valve or piping issue.![]()
