How much oil
ull9
Odessa
Hallo people,
Unfortumatelly the Kubota L185 Ibought doesn't has the owners manual
so sorry for stupid question
How much oil must I (re)fill to the engine?
Thanks
hodge
Nov 19, 2010
2,960
537
Love, VA
Hopefully someone will post an answer for you, but in case they don't, then you can safely estimate by paying attention to how much you drain out of it. Put roughly that much back in, checking the dipstick as you go. Once you get close but not over, start it up so that the filter can fill up, then check it again. Top it off based on the dipstick. It is a little more work, but it can be done safely. I just had to do it with a Bobcat skid steer, with a Kubota engine in it. It held almost 2 1/2 gallons!
ull9
Odessa
Thank you hodge, it looks logical.
Another question how much oil in gear box? but probably I can use your advice also.
If somebody has exact answer I would be glad to get it.. :)
birddogger
433
Pittsburgh
I've seen some marked on the oil filler cap, or right beside it on the valve cover. Some can be surprisingly small amounts, like 2.7 liters or so.
meanjean
Kubota MX4700
Aug 10, 2010
922
Hazelridge, Manitoba
Taken from the operators manual:
Fuel Tank
22 litres
Cooling System
5.3 litres
Engine crankcase
With serial #3659 and below
3.8 litres
With serial #3660 and above
4.6 litres
Transmission
23 litres
Kytim
Aug 14, 2009
848
Western Ky
Most capicities are avail at tractordata.com and are fairly accurate.
