HELP!! M 5400 PTO Probs
BamaFarmer
Kubota M5400
Apr 20, 2017
15
us
Alright guys looking for some direction to head here. I have a Kubota m5400 the pto would work fine until warm and then tall grass could stop the Bush hog. Hooked up a gauge to the PTO valve and only had 70 PSI at WOT. Pushed the lever a touch farther and quickly got 375 PSI. So adjusted linkage, and tightened down. Now the problem is I don't believe it is completely shutting off, at high RPM's the PTO will still spin out of the frame just as if its on. So its either not on enough or way to much, there seems to be no fine line. The adjustment screw on end of valve doesn't seem to change pressure at all either.
Any Suggestions??
8,367
Looking into it.
Do you have the WSM?
And if you do, what does it say for recommended pressure?
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
What kind of maintenance has been done?
How many hrs on machine?
Hrs on hyd fluid and filters?
What kind of fluid did you use?
BamaFarmer
Kubota M5400
Apr 20, 2017
15
us
All fluids fresh, New Filters Hydro filters included all Kubota brand all less than 20 hours ago
1300 hours
UTD fluid
Has new Hydraulic pump also within last 20 hours. all hydraulics otherwise work perfect.
I bought this tractor with a bad pump, and replaced that.
BamaFarmer
Kubota M5400
Apr 20, 2017
15
us
Is it now holding a load when hot?
Pat
Yes it will. but when disengaged will still spin as if its on at High RPM. Can back the linkage back to where it will disengage, but then back to same old story of not enough pressure to engage the pto clutch when hot.
1970cs
1,124
Grand Ledge
I am wondering if the the lever for the valve is loose on the shaft and you have to over rotate to compensate and vice versa when back to it's original setting.
Pat
whitetiger
Nov 20, 2011
3,092
1,523
Kansas City, KS
I suspect that you have a problem with your control cable. Disconnect both ends of it and see if it moves freely full stroke both ways.
BamaFarmer
Kubota M5400
Apr 20, 2017
15
us
It does move freely both ways. its like when set for it to fully disengage it needs another 1/4"-1/2" range of motion to fully engage.
I am wondering either A. if the valve is maybe trashy and not opening soon enough?
or B the cable is stretched out too long over time.
BamaFarmer
Kubota M5400
Apr 20, 2017
15
us
I finally spoke with a tech. He says the PTO valve lever should not impact the amount of pressure I have by pulling it further in motion, (gain or loose pressure by the farther it is pulled) it should either have the pressure it needs, or not(be off), and believes the valve is dirty. Can anybody second this process?
BamaFarmer
Kubota M5400
Apr 20, 2017
15
us
Well I pulled the pto valve off, pulled it all apart cleaned it, and reinstalled. Same results as before. I'm bout to pull my hair out with this one!!!
harleyman80
tn
So what did you find out? I am having the same exact problem. all the way down to the 70 psi and adjusting the pto cable.
BamaFarmer
Kubota M5400
Apr 20, 2017
15
us
I believe I had narrowed it down to needing a new valve and or pto clutch. Had a guy offer me enough $$ for the tractor I was happy.(He done tractor work on the side, figure he wasn't scared to split it down) and I went and picked up a m6800 newer in better condition up the road for almost the same money. Life is well and the 5400 is someone elses headache now.
harleyman80
tn
thank you, I will let everyone know when I find my problem. Waiting on Kubota to call me right now. Dont wanna split it if I dont have too.
