Has anyone tried this (Snow removal)
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,181
872
PNW-WA
I use my frame mounted snow plow only. I have a big area, but I don't need everywhere accessible for parking, backing into, and turning around in.
I've dealt with a gravel drive and parking areas for 25 years now. I've always had a reserve pile of gravel for when it melts. Between the Rock Rake and the Snow Plow, shaping things has been generally easy.
I get nowhere near the amount of snow a lot of you do. Some of you get hit heavy!!
5,849
Used to have what's now called a 'box blade' on CJ-5. backup to client's garage, drop it and plow,out to road, lift 'box blade', tidy up and collect $30, back in 1977..... easy money and lots of repeat business.
Bearcatrp
Mar 28, 2023
1,037
658
Minnesota
You lack enough HP/ Tractor to run 2 blades at one time!
Now you have me re thinking this. Was about to go get the blade but backing off. Is it the weight of both blades used together of just the snow would be the issue? I did just change out my turf tires to skid steer tires for better traction.
9,485
It's a combination of weight (blades and snow) lack of HP (snow gets heavy and hard to push) lack of weight tractor (the blades will shove you all over the place, front and rear), lack of traction (your going to be really unhappy with skid steer tires unless you have a good set of chains for them!
This is all based on your terrain being flat and manageable, if you have hills or grades then it gets even worse.
Bearcatrp
Mar 28, 2023
1,037
658
Minnesota
Thanks Northern Idaho Wolfman. Will see how it goes with just the pusher and blade and go from there. The way our weather is going, may be little snow this year. We have 50's coming. Nuts.
WFM
L3800
Apr 5, 2013
1,524
971
Porter Maine
Step in....help him out.
Unfortunately Uncle could buy and sell me ten times over...I will blow my own horn by saying I just bought him a BX step from specialty repairs in Newfoundland Canada, step and bracket $360. Bucks(merry Christmas) he's ungodly wealthy because he doesn't spend a dime...
