I know I have seen this subject before but for the life of me I can't seem to find it using the search. So pardon the duplication.
Have 2008 BX2660 that I purchased used about 3 mos back. Finally got the FEL installed and had my first need for 4wd. Once in 4wd it was very difficult to get back into 2wd. Pulled on the lever as hard as dared, rocked the tractor a bit backwards and forwards using the HST, no luck.
Finally jacked it up, took the right rear wheel off and tapped the lever with a hammer where it went into the housing. Slipped right back into 2wd so not sure if it was the hammer jarred it loose or the fact that I jacked it up and the rear wheels could now turn free. Sprayed some lube where it went into the housing but don't really think that made any difference.
Went back to using it and did have several occasions where I had to rock the tractor backwards and forwards using the HST pedals to finally get it to release from 4wd.
Is there some magic trick to making this easier, or adjustment in linkage? (although I certainly don't see one).
