i take it i would have to plant the pumpkins by hand? i didn't know it there as a planter you could buy to pull behind a tractor. i have well waterAhhhuummm right now I would plow up where you want to plant them.. then in the spring contact your county agent have the soil tested to see what it needs, then do some YOUTUBE search on planting pumpkins. Watering,, probably a long hose and a by pass on the water meter
very nice. looks like hes planting one seed though? i always though you put 3 or 4 seeds in a hole? thats what i did in the garden anyway. i have one row planted and it has taken over more thasn half thae gardenA neighbor used to have a wooden version of this:
https://www.youtube.com/watch?v=hcCCv1XiUYE
The hills need to be ~3' apart, so a planter intended for rows won't work without modification. Most of the vids on YouTube had the seed bin and plates removed and they had someone dropping the seeds by hand.
in my garden i pruned for a little bit thinking i could keep up. i was wrong. i planted one row and it has taken up more than half of my garden, and my garden is 50x25 feet. goot thing everything else is harvested otherwise the vines would be taking over the plants. this is why im looking at a bigger area for pumpkinsThe idea of planting several seeds in a hill was to assure that something germinated. Then after they sprouted you should go through and pull the little ones and leave the large strong ones,,, Me,, if it comes up it stays !!
i have live at this house for 2 years now, last year when i didnt plant i had some pumpkins come up in the corner and ket the seed and planted them this year. i bought a package of seeds and planted those as well. NONE of those germinated, but the ones that i kept from later year took off. i planted one long hill, am i suppose to do seperate hills for each seed? i planted one long hill and my pumpkins have taken over half the garden, this is why im looking at a bigger area for pumpkins, and the kids love them and i want to sell a few.It should say on the seed package how many seeds should go in a hill. I don't grow pumpkins, but on cucumbers, I plant several seeds and thin the hill down, but I only plant one hill of them. I'd probably rethink things if I was doing it on a larger scale. Going off of memory, a half acre should be about 20000 square feet? If your hills are 3' apart, you're going to have 2000 hills if you waste 10% of your space. You probably could thin 2000 hills, but might rather just plant what you need and just write off the hills that don't come up, or replant them after everything is already up.
i have some good compost, manure and corn stalk, from a year a go that is broken down, im thinking of plowing up some land here soon with my middle buster and spreading some of that out and tilling it in.I would get the soil tested now, not in the spring. If it needs lime, get it applied this fall so it has a chance to start working. Waiting till spring to test and apply is to late if you want good results for next summers crop.
now im thinking about tilling up the area i would use and leave the area btween the rows as grass. would that work?The weed mat is definitely a mixed bag. I have used it under wood mulch in flower beds and to make walkways in the veggie patch. The downside to using it under the winter squash type vines is that it stops them from developing extra roots where the vines touch the ground, supposedly that helps to defend the plant against some kind of vine borer. I don't know that I've seen that work. I have had plenty of squash bugs, the kind that suck the life out of the leaves, both with weed mat and with straw mulch. Weed mat seems to give cover to burrowing things and mice, not good as I've found when it is close to the house. It does give you a headstart on the weeds though, and helps the muddy boots problem.
I think if I had lots of room like you have, that I'd put the rows/hills plenty far apart so you can till the weeds under until the vines really get going and then they can hold their own.
