Gravity fed or elec pump diesel tank...
BigRed57
L2350 4x4 land pride 4ft bush hog
Jun 29, 2016
70
Society Hill S.C.
Has anyone fab'd their own diesel tank whether it be gravity fed or electrical. Just traded a L2350 for a L4060HSTC. This tractor loves diesel mowing at 2k rpm. Looking for a 50 to 100 gallon tank to put out at home that doesn't cost an arm or a leg. I have searched clist but was hoping you guys had done something more interesting. Pics if you have any. Thanks
BigRed57
Jun 29, 2016
70
Society Hill S.C.
I have but I figured there would be more people with some creative ideas on here. I'm tired of lugging (3) 5 gallon jugs on and off my truck. Plus holding them up to unload them into the tractor.
8,191
Simplest, 55 gallon drum and a hand pump.
You could use a fuel Caddy too.
(33 gallon square tank with wheels and a hand pump)
More inventive, Semi fuel tank with an electric pump. ;)
bmblank
Mar 4, 2015
689
347
Cadillac, MI
Fuel companies generally don't like filling smaller tanks (less than 500 or 1000, depending on the company) so you might consider something you can bring to the pump. One that goes in the back of a truck with a hand pump or 12v pump might be what you're looking for.
Sent from my XT1254 using Tapatalk
6,284
Seem to be able to find these 300 gallon tanks with stands all day long.
Or these:
scdeerslayer
MX5200DT
May 23, 2016
434
SC
Growing up my dad had 2 55 gallon drums on a stand that he got filled so often, used gravity to fill the tractor. After that at one point he had a steel tank that was 200-300 gallons sitting on concrete with a hand pump that cranked back and forth and would fill a tractor surprising fast. Now we just buy fuel 5 or 10 gallons at the time.
One thing to consider though is how long you plan on keeping the fuel. These new tractors are more sensitive to bad fuel. One dealer told me the most common issue with the new tractors is bad fuel, usually from sitting in a large tank too long.
BigRed57
Jun 29, 2016
70
Society Hill S.C.
The tank will be in a heated and cooled garage with a dehumidifier. No worries there. I just figured someone had a neat set up on here. Someone has to have a guzzler that's worse than mine. Guess I'll have to be the creative one and post pics when done.
BigRed57
Jun 29, 2016
70
Society Hill S.C.
Found a nice used 100 gallon tank with gpi 15gpm pump for $200. That was a steal. Time for some Kubota orange and blue/gre paint..pics to come
Knott
2015 BX2670-1, BX2755HD Snow Blower, Farmking 4' box Blade, BX 2760A Plow Blade
Jun 2, 2015
101
Manitoba
I put this together recently to make fueling easier. It is a 12 volt pump run by a marine deep cycle battery, maintained by a battery tender charger. It works very well. When it is empty I remove the hose assembly & put the tank in my truck with my pallet forks, & remove it the same way when it is full.
coachgeo
Nov 16, 2012
2,459
37
Southern OH
How do you post your pictures in that size?
not sure whom your refering too.. if it is Knott.. his pics are hosted on Taptalk via image links. BUTTTT...
we would rather it NOT be done that way. Rather they be hosted here on our board. Odds are extremely high pics hosted someplace else will get moved or deleted and the good information in here they refer too goes bye bye making the post there in worthless. I bet taptalk will not host this image for very long.
mdhughes
L3901DT
Dec 10, 2014
1,301
922
Ste Geneveive county, MO
I bought a 100 gallon transfer tank and mounted it on a home made skid. I also brought a Fill-Rite 12-volt pump that I power from the tractor. I used pallet forks to load the tank in my truck when I need fuel and take out the same way. I posted on the forum about the connector I put on the tractor and pump to power the pump, see this thread for details..
BigRed57
Jun 29, 2016
70
Society Hill S.C.
Yeah thats exactly what I did. I was wanting to post the pics for you guys but don't know how from my iPad. Painted my tank Kubota Orange. The only color. :)
BigRed57
Jun 29, 2016
70
Society Hill S.C.
I painted my tank kubota Orange and placed it on 4x4's with casters to roll around in my shop. It helps a lot when the tank is full.
BigRed57
Jun 29, 2016
70
Society Hill S.C.
And after two good coats of Orange and some legs and casters....here she is..currently awaiting a nice grey Kubota decal. Plus my combustible decal
