gr 2110 cutting problem
dogboy
2008 gr2110 mower
May 2, 2010
st. louis mo.
hello i`m john
my problem is my kubota gr2110 leaves uncut grass when i cut my yard this tractor has only 36 hrs. on it
i have checked tire pres, deck specs. i`ve had three sets of blades on it i use a mulch kit , and i have removed it and tried that.
it`s been back to the dealer 2 times and i have talked to the district rep. three times
all they tell me is that they have never had this complaint before. the dealer even saw how it cuts
i`m at my witts end with this thing
can anyone help???????????????
thank oyu
john:mad:
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
Sounds like your travel speed might be a tad bit to fast for the blades to keep up with. Try slowing down your travel speed and see what that does.
dogboy
2008 gr2110 mower
May 2, 2010
st. louis mo.
eric.thanks for your reply.
i`ve tried different speeds,i`m cutting so slow now that it takes me twice as long to cut my yard.
there has to be a problem elsewhere or a design flaw
thanks
john
avi8tor
L2800DT, BX2380, RTV X900
Mar 14, 2010
101
Cleveland, Alabama
Just a stab in the dark - are your blades on upside down? are they turning in the correction direction?
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
At what height do you have the deck set to mow. Perhaps maybe its up to high and it looks like its not geting cut. An ideal height for grass is 2 1/2" to 3" in height. I wound not recommend going shoter then 2.5"
traildust
B7610HST 4WD, LA352 FEL, Gearmore 2 Spool Top & Tilt Box Scraper
Jan 27, 2010
1,490
Phelan, California
That's actually two stabs :cool:
Although good ones, ya never know with the basic's. Maybe the battery cabels are crossed :D:D:D
avi8tor
Mar 14, 2010
101
Cleveland, Alabama
I never could count or spell :)
You never know about those battery cables :D
I've had similar problems in the past after my son has worked on my mower. He isn't the sharpest tool in the shed.:D
dogboy - I have had a problem with a liner bolted inside the mower deck coming loose, which pushed the grass down and the blades going over the grass. I don't if this is your problem, but might be something to check.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
77
Rocky Face, Georgia
The grass that your mower is not cutting wouldn't happen to be where the tires are running over it first is it? If it's tall stem grass I don't think it matters what kind of mower you have it will miss some.
Just for the sake of asking, what RPM are you running at?
traildust
Jan 27, 2010
1,490
Phelan, California
I would swear I responded to this earlier - what happened :confused:
Me two :D
I may not but sooooomebody around here sure does :rolleyes:
Be very careful, since I've heard the fruit doesn't fall far from the tree..HA HA HA :D
dogboy
2008 gr2110 mower
May 2, 2010
st. louis mo.
avi8tor
thanks for the tip.
right now i have a mulch kit on it and it does have a plastic piece under the deck.
i will check it out
john
diesel1432
GR2110 snow blade
Feb 12, 2011
illinois
Just joined I know this post was along time ago . I had same problem have your dealer adjust your pto when it engages .....
