Getting b2650 next week, drawbar questions
wacnstac
loader, forks, box blade, disc
Apr 3, 2018
60
Wellston, MI
What size is the hole in the drawbar? Is the drawbar fairly hefty or should I invest in something else?
3,261
it will accept a 3/4" diameter pin.
5,144
941
Most are very strong not some low grade steel.
It is rare to see one bent. The only one or two I have seen bent were on super large tractors towing liquid manual spreading tank wagons and someone turned too tight.
barmstro
b1860, b2650, front end loaders, box blade mmm, rear and front snowblowers
Dec 1, 2017
25
minnesota
very hefty, I could not imagine hooking up the tires well enough to do any damage at all.
5,329
It's possible that the paint is making the hole smaller, Just drop down to a 11/16 pin, still plenty strong enough.
Stmar
B2650HSDC
May 23, 2017
906
42
Buffalo, Wyoming
Hmm, I did buy the 3/4" and it will not quite fit....
I can't remember what size clevis pin I got but I did have to use the dremel and grind it just a smidge. I did not do it enough to compromise the pin strength. Had to go with the large clevis because a smaller one did not have a pin long enough to work on the draw bar, so you have a couple of issues: length and diameter of pin. My situation may be unique because my options are not plentiful, rural area, and I have to make do with what I can find.
