What size is the hole in the drawbar? Is the drawbar fairly hefty or should I invest in something else?
Most are very strong not some low grade steel.What size is the hole in the drawbar? Is the drawbar fairly hefty or should I invest in something else?
I can't remember what size clevis pin I got but I did have to use the dremel and grind it just a smidge. I did not do it enough to compromise the pin strength. Had to go with the large clevis because a smaller one did not have a pin long enough to work on the draw bar, so you have a couple of issues: length and diameter of pin. My situation may be unique because my options are not plentiful, rural area, and I have to make do with what I can find.Hmm, I did buy the 3/4" and it will not quite fit....
