flushing fuel tank on l2350
ljb
l2350 , zd28
Feb 11, 2024
new wilmington,pa.
hey guys got my machine running hooked up aux tank and new filter but brown crud and rust in filter any thing i should do other than running fuel thru lines and changing filter again tank looked difficult to remove thanks once again
9,203
You best bet is to take the time to remove and properly clean the tank.
Flintknapper
L2350DT
May 3, 2022
1,971
2,498
Deep East Texas
Removing the tank on a L2350 wouldn't be any picnic.....but would be the best way to clean it as @ North Idaho Wolfman suggests.
That way you can turn it all angles. Use abrasives and solvents if necessary and be able to dump all of that out of the filler neck.
IF you only had bad fuel to replace....then yes 'flushing' might be prove adequate.
But anytime you see 'rust'....it needs to be removed and that's not going to happen just flushing it.
Elliott in GA
Mar 10, 2021
803
808
North Georgia
You could buy something like this (see below) for $30 to carefully inspect the inside of your empty tank. Afterwards you could make a more informed decision.
I would expect that removal and complete cleaning will be required, but if there is just some very light rust - spraying the inside of the tank with acid (then flushing repeatedly) might be enough.
6,905
If it's just rust put a neodymium magnet with a wire through the center hole and swish it around and you'll get most of it out. Then put a good loop the the end of the wire near the top and leave it in the tank. The loop is so you can later hook that loop and get the magnet out. You can then pull it out from time to time to check for more material.
2,341
Here is a link to what I did with my rusted fuel tank on my L185.
in short, it rusted, cleaned it and that caused holes in the bottom, repaired with epoxy coating that lasted 6 years, replaced it with a used one from @007kubotaguy
